Hello all. I was wondering if anyone would know if there are tank end caps that would fit either styrene or brass tubing in order to build CF's horizontal chassis mounted air tanks or the frame/bracket behind cab vertical air tanks. For the very early cabover Freightliners, CF had the vertical tanks installed inside on the right side of the cabs. Later on the chassis mounted vertical tanks (mostly on cabovers) and horizontal air tanks (mostly on Freightliner conventional's ) frame mounted horizontal air tanks. I haven't begun this build yet and am still in the info. gathering stages so I'm not sure what my vertical behind cab air tanks diameter will be yet, but it will at least be somewhere between 3/4" to 1" in diameter. I am looking for some domed tank end caps that will fit tube cut to length to represent the air tank bodies. Any help that you may be able to provide will be greatly appreciated. Thank you all ,Pete
