41CHEVY
1960 GMC Cracker Box Build 10/1
While the Bandag defiance is sitting for a month or so the let all the putty and filler dry and shrink I'm starting  a GMC Tilt Cab Cruiser or Crackerbox.
First thing is to start the distinctive " fish belly" chassis, The start of the cross members and air ride pads and rear trailing arm mounts..
2v2uJm8jnxAhT9W.jpgHosted on Fotki
2v2uJmMQGxAhT9W.jpgHosted on Fotki
2v2uJmM6nxAhT9W.jpgHosted on Fotki
2v2uJmMPgxAhT9W.jpgHosted on Fotki
Edited by 41CHEVY
Looks great so far!! I plan to build one of these in the future. Mine will be a straight front axle. I'm guessing that you're going independent in the front?
7 hours ago, DRIPTROIT 71 said:
Looking forward to seeing this one!!
I'll have some photos tomorrow of it. Thanks to pins and power tools it is not too bad.  Paul
Basically 99% scratch built form micro I beam, tube and 160 thousands plastic carved into main cross member and straight pins for pivots.  All suspension moves and all linkage steers as the real ones.
2v2uJmMYFxAhT9W.jpgHosted on Fotki
2v2uJmMF5xAhT9W.jpgHosted on Fotki
WORKS !!
2v2uJmMqyxAhT9W.jpgHosted on Fotki
Picture013-vi.jpgHosted on Fotki
2v2uJmMGFxAhT9W.jpgHosted on Fotki
2v2uJmMLGxAhT9W.jpgHosted on Fotki
2v2uJmMUGxAhT9W.jpgHosted on Fotki
2v2uJmMiGxAhT9W.jpgHosted on Fotki
Air tanks and radiator fitted
2v2uJmM7dxAhT9W.jpgHosted on Fotki
Got the details on the air tank mounts added, rear cab pad, the exhaust "rattle box" done, fifth wheel plate mounted and partial details added and the fuel tanks built and detailing started.  Started the cab. Cut the sleeper area down, made a grill for it and added vent window posts. The windshield divider was a bit of work as the windshield is Vee'd only 10 degrees.
Picture0012-vi.jpgHosted on Fotki
Picture0055-vi.jpgHosted on Fotki
Picture006-vi.jpgHosted on Fotki
Picture007-vi.jpgHosted on Fotki
Picture008-vi.jpgHosted on Fotki
Chassis  is moving along. Made up battery boxes, steps, fifth wheel plate and turntable, dryer, air filter can, hinges , 9 shots to coil up the mud flap holders and fabbed up splash guards in front of rear wheels. Got the interior almost complete including the GM/Fuller Electro-Shift 10 speed selector set up. Probably forgetting a lot of parts added too.  :)
Picture0013-vi.jpgHosted on Fotki
Picture0024-vi.jpgHosted on Fotki
Picture0044-vi.jpgHosted on Fotki
Picture0061-vi.jpgHosted on Fotki
Picture0034-vi.jpgHosted on Fotki
Picture0014-vi.jpgHosted on Fotki
gmint1-vi.jpgHosted on Fotki
gmint2-vi.jpgHosted on Fotki
Chassis is painted in Testers Acryl Metallic Blue and most all the running gear is detailed and in. Started making up the air intake, exhaust and brackets. Signal lights are almost done, as are Mirrors and brackets along with the outer door handles and P.E. wiper blades. I'm pleased with the results.  Paul
Picture0035-vi.jpgHosted on Fotki
Picture0015-vi.jpgHosted on Fotki
Picture0026-vi.jpgHosted on Fotki
cabparts-vi.jpgHosted on Fotki
Yup, I’m an idiot, didn’t look thru all the finished builds that are posted yet.....
that came out great😎
  • Haha 1
