41CHEVY
Easy GPS unit for modern trucks
With all the new tech put on newer semi's the one thing missing that is most visible on a model is the GPS saucer. Less than a 1/2 hour I made up a half dozen for my Mobius International buils. .I use the dish shaped plastic seal from the 1/2 gallon juice containers, either 5 minute epoxy or the stick epoxy. The 5 minute gives less air voids. After it cures I sand the bottom flat and glue a 015 plastic disc to the bottom with CA glue. Sand the sides flat and take a piece of square tubing cut at a 45 degree and glue to botton to make the cab mount.
  Here is a photo  how to.   Thanks for looking.   Paul
gpssatdish1_zps93837b94.jpg~original
gpssatdish2_zps35841a28.jpg~original
gpssatdish3_zpsc00f39a5.jpg~original
All mounted up with the cable run under the cab.
wally5_zps16478d73.jpg~original
I can't get thew photos to open. Could you repost them. Thanks.
